Zero Tolerance 0300 Series??
I'm probably gonna buy the Tan handle version soon, i have one concern though.... Does the stop pin/thumb stud look sketchy to most of you guys???? How is this set in place?? Is it pressure fitted, screwed type etc?? It looks like it is forced in/pressure fitted into the blade, this leads me to believe that after years of use, it will wiggle itself loose and fall out.
If it is a screw typ thumb stud/stop pin, i can only hope they used the red loc tite.
Looks like a sturdy folder, but i wish it had even another stop pin in the liner/handle.
Pressure fit via hot/cold process. Wont fall out, if it ever did, they will fix it without an ounce of hassle.
Buy one now so you don't miss enjoyment time :D
I don't think it will be a problem. The ZTs are outstanding. And like J_Curd said if there is a problem it will get fixed.
