I'm curious; is it a gen 1 or gen 2? In any case, all of the afore mentioned remarks are well within their rights. The issue could be that the pivot is too tight/your hand is in the wrong position/the knife is not as well cleaned or lubed as need be, etc. Another note on opening via the thumb stud: begin with your thumb pointing directly toward or on the pivot in a straight line from the butt, then move only your thumb to the point rear of the finger choil, arch your thumb so that the tip of your thumb is on the point, move your thumb swiftly to the thumb stud and follow through. If you by chance have a blur, it's the exact same form and function without the ramped thumb stud and speedsafe. Work on your technique for a few days, then I would suggest possibly adjusting the pivot. Also, if you believe the detent has anything to do with the situation you can leave the knife 1/2 opened at night, putting constant pressure on things, possibly making things work a bit easier for you.
