Zero Tolerance 0561 Loctite?
Hey guys, I have the Zero Tolerance 0561, and I love it. But it has one minor issue. The knife rattles in both the open and closed position (I assume this has to do with the ball bearing system in it?) Is this something that loctite could possibly fix? Should I even put loctite on it? I am just looking for good, general, overall maintenance for this knife. Thanks guys.
Where will you put the loctite, on the bearings?
NO! Just send it back. Or try the loctite on the bearings and let us know how that works.
Why don't you take it apart and see what the issue is? If the blade is tight, then there really isn't anything in the that CAN rattle other than the bearings.
Take it apart, noticing how everything came apart. Take pictures if you have to so you can see how it goes together. Very simple to do.
Then lube the bearings as you put it back together. Use something heavier than WD40, a little oil from the garage if that is all you have. Grease would be better if you have that. If you have no oil or grease, try Vaseline. A little goes a long way with all of them.
The rattle should go away. If not, then you can send it back if you have to, but A) you probably will fix the problem and B) you will know your knife much better as you know what it looks like inside.
Locktite will not fix the issue. Locktite is basically a glue and if you put it on the bearings all you'll do is glue them to the carrier they ride in and then they will no longer roll, thus, your knife will not open. Fasten that thing back together and you'll have a much bigger problem.
Main thing is to make sure you have the correct size Torx bits for the screws, make sure they are just snug enough to fit so that you do not round off the inside corners of the screws when you put it back together.
Tighten the big pivot down just enough that you do not have any blade play side to side when open, but not so tight that it is hard to open. The perfect tightness you'll soon discover, no play but opens ok.
If the blade is not centered, and has a bigger gap on one side than the other, loosen the pivot screw and the other screws a little bit, and push and hold the blade against the side of the handle that has the bigger gap as you slowly tighten the pivot screw again. That should center it up. Tighten up the big pivot first, find that "sweet spot" again, then tighten up the smaller screws.
And there you go! Much faster than sending it back to Oregon.
Hey guys thanks for all the information! It did seem odd to me to put loctite but I read in more than one place that it could possibly help fix it. I was never comfortable using loctite on my blades, especially one that is pretty steeply priced. I did take the knife apart already, I always like to service my own blades. As you said jmclfrsh, it is good to know your own blade anyway. I just couldn't really tell where the rattling was coming from. In all honesty, the knife is amazing still. Still works like a dream, it is just noisy. I might have to try the grease idea. I just wanted to hear your opinions. Thanks a ton guys!!!
Did you tighten the pivot more.
Seriously I work on 1 or 2 every week. They can all be tightened to pinch the bearings if you want.
Ive not seen any rattling after tightening them up.
Either way, enjoy your knife. It sure is a good one!
Take care.
Matt
He BellaBlades, I did try that already, sorry I forgot to put that in the last reply! I did already try that and that is why I was confused because usually that works! But thank you for the suggestion I really appreciate it!
One thing that I've come across in my research on this knife is that the stop pin can be loose. You can test if this is the culprit by shaking the knife in both the open and closed positions. It should rattle when open and not when closed. For this, you could try re-seating it or send it in to ZT for them to outfit it with a slightly larger pin. Hope this helps!
