I bought a ZT 0770CF a few weeks ago and have loved it so far, it has an elmax blade which is a first with this type of steel for me.
i know it says in the manual that comes with the knife that it is sharpened between 20 and 22 degrees i think, so once the factory edge got dull i decided to go with an 18 degree angle to see if it would be that much better.
i used an edge pro starting with the 120 stone working all the way to the 6K paper and it was ridiculously sharp and would cut better than pretty much any other knife i own UNTIL i decided to see about this HARD USE claim.
i really didnt abuse it but i ended up with tiny chips or possibly the blade rolled some im not sure havent had a change to get it under magnification. i cut up some ethernet patch cables and it cut with no problem but i noticed the issue afterwards. i only have pictures from my phone with no macro but i believe you can see the issue.
i am a newbie when it comes to sharpening and using different angles so this may be my fault i am sure there is a reason there is a recommended angle i just didnt think three degrees would make the edge that weak.
