- Aug 28, 2013
Hey guys, I've got a ZT 0566 that has vertical blade play in the closed position. It was de-assisted then modded significantly, to the point that I don't think KAI's warranty department would want to mess with it (although none of the mods had anything to do with the detent ball).
Anyhow, the blade play is due to the detent ball either being flattened down, sitting too low, or the hole in the blade being too large. It's not caused by the lockbar, because with the blade closed and putting full force on the lockbar it still has the same amount of vertical blade play. So now I'm to the point that I want to just replace the detent ball, although I'm really pretty nervous about it and wonder if anyone here has actually replaced one of the detent balls in a Zero Tolerance knife? It looks like they are 1/16" balls, but I'm not entirely sure about this. I figure if I'm going to replace the ball anyway then why not upgrade it to ceramic? I've also thought that I could just turn the flattened detent ball over thus assuring that it's the right size...but really haven't made up my mind either way.
I guess my main question is whether anyone here knows the size of the detent balls used by Zero Tolerance, specifically the 0566. And if there are any not so apparent problems that I'm missing before attempting this mod. Any advice is greatly appreciated!
