Macchina
- Apr 7, 2006
I got a Kershaw ZT 0200 about a month ago. I've carried it for about 5 days and have used it to open a few boxes. I've opened it under 100 times. The lock bar started out engaging about half of it's width, perfect for a nice long wear-in. After opening it about 80 times, the lock bar is now a little more than fully engaged, a little faster than I'd normally expect from a liner lock "settling". I was looking it over yesterday and noticed that the liner lock does not engage along its entire height, but instead only at a single point! It is a little hard to see in the picture, but the liner lock touches only on the very top corner. I can see light both along the height and width of the liner lock. The rest of the contact surface angles away to allow about a 0.020" gap at the bottom. I added a rudimentary sketch to demonstrate what I mean. I don't if I should send it in to have it replaced, or use it and risk premature wear-out (Maybe it will wear in, but it looks like the liner lock will go to the far side before the bottom touches the blade). I compared it to my other liner locks from benchmade, Spyderco, and Kershaw and they all show full contact with the lock bar. I have never sent anything into Kershaw, but have been scorned by other knife companies for sending in expensive knives with bent blades and blade play. If anybody else has a ZT 0200, could you check this out and see if it is how they all are?
Thanks,
Michaelmcgo
Thanks,
Michaelmcgo
