I have deassisted my 0350, and blade is centered with original factory washers installed.
Flipps like a dream in ANY position (right-side-up, up-side-down, side-ways, pinky-flip to reverse-grip, etc. etc.).
As KnifeDreams stated, it made it twice the knife in my mind also (much better likability for me, and everyone who has handled mine, compared to assisted option). I would not have a 0350 any other way!
Differing diameter washers should have no effect on blade centering.
Chances are, in your particular situ (assuming knife was centered before de-assist, and nothing else changed) that the knife was as some point assembled with a little tension in the scales/liners that was being overcome by the torsion bar being installed. More than likely a simple assembly adjustment is all that's needed.
1. Loosen all the fasteners 1 - 1.5 turns (until they are slightly free)
2. Tighten the blade pivot screw.
3. If blade is off-center, put pressure on it laterally slightly beyond center in opposite direction.
4. While putting pressure on blade (slightly beyond center) alternately snug up all fasteners.
5. Tighten all fasteners (don't reef on them, just tighten them snugly).
6. Relieve pressure on blade & compare to previous assembly.
7. Loosen pivot screw and adjust action to your liking.
8. Possibly readjust to tweak one way or the other repeating above steps until it's to you liking.
9. Depending on your preference add thread-lock tape or compound/liquid and let knife sit (so as not to get compound into pivot area as it dry's.
If this sounds too complicated, PM me and I will help you further.
Regards,
Chris
