Hey guys thank you for the links and info on the Chiol mods.. Looks like if I were to do this I would run into the same problem with loosing the born on date.. I may try it out later on though.. ..
Sorry Cutter17 for bouncing around with the replies about the pivot screws.. Here is a direct link for anyone else that reads this
http://www.bladeforums.com/forums/showthread.php?t=530415 post #13
Also to answer your question about if there was anything to watch for while tearing this knife down.. Here is one thing that might be helpful.. When doing so Start with the pivot screw on the switch side.. in this order..First the pocket clip, the pivot screw, Then the scale screws..
Watch out when pulling up the G-10 scale because the Button switch is attached to the slide lock and when you start to pull it up the button, scale, rubber boot and slide lock will all come off as one.. watch the 2 plunger pins and springs.. Have the blade open about 1/4 -1/2 way to let the tension off the locking mechanism and this Will make it a bit easier.. also when putting it all back together have the blade in the same fashion..
Then when you get that all off, the rear spacer pin on mine was in there pretty snug and just use care going from one end of the knife to the other applying pulling pressure to get them apart with out damaging the rear spacer pin.. Hope this helps..
I probally made this all sound harder than it actually was .. To me it was pretty easy.. I try not to let knives or anything for that matter intimadate me from taking them apart.. Just keep an eye on how it all comes apart and take your time.. take pictures of it if that would help you keep a record of how it came apart so that you will get it all back in the right order..
This knife has a heck of alot of parts to it compared to a regular folder but is a fairly simple design.
