- May 20, 2012
Hi, so I got a new zt 0551 about a week ago and have been loving it. It had a tiny bit of lock rock so I decided to try extending the lockbar to the right after disassembling it to try and remedy this, when I put it back together it was much stiffer and the bladeplay in all directions was worse...So I tried extending it back the other way without taking it apart and still, its worse than before...Its stiffer, has blade play, less fresh detent and Im so pissed at myself...Before I took it apart, everything was so silky smooth, the blade would practically fall in the handle and now it is so stiff and has even more play than before.....Do you think it has something to do with the fact that I cleaned out the grease and dirt and stuff inside and put some tuf-glide on instead? (which is a much thinner substance) Or do the washers have a specific orientation they need to go in as? I put them on the right sides but one side of each washer was dull and a bit banged up and the other was more smooth, does it matter if the dull or smooth side is the one facing the tang? I really dont want to send this back to kai because I live in Canada and do they even still warranty knives that have been taken apart?
Please help me remedy this,
Anthony
Anthony
