I just bought a used ZT 0562CF on the Exchange. The blade can be wiggled/rattled a tiny bit along its path of travel when it is between the open and closed positions. The blade does not move side to side at all but rather rocks back and forth a tiny amount, about 0.5 mm, at the blade tip. It is easily felt when jiggling the blade or shaking the handle. The movement can also be heard when placing the handle spine/back against a wood table and jiggling the blade back and forth.
I suspect it is the movement of bearings within their cage, but my ZT 0801 doesn't do this and I think they use the same bearings. Otherwise the movement of the blade is perfect. I am kind of new to higher end knives. I could probably post a YouTube video but hopefully my description makes sense enough.
Is this normal for the 0562CF, what could the cause be, and how should this be fixed? It doesn't affect use but it doesn't seem right. Thanks.
