- If I can get my hands on the CF 0560, Miltec-1 grease was what I was planning on using. It's like butter on the other knives and guns I use it on now.I recently greased my 0560 bearings with some Militec-1 I had around. Slicked it right up. So far so good!
I actually called KAI yesterday and asked this exact qeustion. They said that a mixture of tri flo lube and silicone grease is used on the KVT system.
Anyone know a good silicone based grease? Is militec silicone based?
It is so safe that MILITEC-1 was even approved environmentally by the U.S. Navy Medical Command for use aboard nuclear-powered submarines."
via their site
That being said, we don't have any on board. Otherwise, I wouldn't have had to buy my own, lol.![]()
Nice, only confirms what I had been doing for the past few years [mixing oil + grease] for best effects for most folders.
"WHATS IN MILITEC-1?
MILITEC-1 is a chemically-reacted synthetic-based hydrocarbon derivative. At the start of the manufacturing process, MILITEC-1 is composed of a blend of several extreme pressure lubricants, natural anti-corrosion ingredients, extremely stable chlorate esters, anti-wear components, and anti-oxidant compounds. This blend is then introduced into a chemical reactor. When MILITEC-1 emerges from our proprietary chemical reaction process, it is no longer a blend. It has been organically bound into a unique, pure, uniform single substance. In its finished form, MILITEC-1 is completely stable, so it does not require agitation before use.
Just as important as knowing whats in MILITEC-1 is knowing what isnt. MILITEC-1 does not contain chlorinated paraffins, PTFE, fluorine, solvents, carrier oils, viscosity enhancers, metals, molybdenum disulfide, zinc, sulfur, graphite powders or other solids. Its also important to realize that MILITEC-1 is non-hazardous, non-toxic, and non-combustible. It is so safe that MILITEC-1 was even approved environmentally by the U.S. Navy Medical Command for use aboard nuclear-powered submarines."
via their site
really? I thought if you go to their site troops get a free supply o.o
ps. if i read into your comment correctly, and it means your working for the navy, Thank you for your services!
pss. same tox green kraid?
