ZT0300,any Lefty feedback?
I'm very tempted to try this one out,but being a lefty....:confused:
So,any lefties out there using it?Would you recomend it even to an lefty?
Will Kershaw ever consider a lefty production run?
Greetz,Alex
P.S.:Righties please chime in too naturally))
well the flipper would be great for opening thats for sure. the lock however might be a bit more tricky. it wouldn't be that bad imo, but i dunno, im a righty
It is very lefty friendly. You use the flipper to open the assisted blade and not the thumb studs. I have had no problems using it and it fits my hand very well.
You can close it one-handed lefty , also.
I am left-handed.:thumbup:
offsetlover+Daniel,
thanks for your advise so far :thumbup:
Daniel,
How it's using the knife left handed?
Closing you say isn't a problem...:rolleyes: ohoh,I want the knife more and more))
I think opening should be anyway the same for both,left and right,no?Ambidextrous thumbstuds+flipper...
I don't use the thumb studs. I feel that they are actually designed as blade stops rather than opening devices.
I have cut myself using thumb studs on assisted knives because my thumb follows through like on a normal thumb opening knife and then hits the blade.
Using it is no problem. The clip (although on the wrong side) doesn't present any problems.
It is a bid strong and heavy knife--if that is what you will like, then you should be very happy with it as a lefty!
The clip should be a non-issue, there are four sets of holes threaded for the clip; left or right-handed, tip-up or tip-down.
Yes, it does, but I seldom move the clip. For me, it seems to feel better mounted on the right-hander side.
