Zt300 low rider?
Ever do one for the 300's? I love the shorter clips but want it more hidden
Also do I need to mail you the blade?
I can't do a low rider to work on any ZT clip. The hole pattern is too close together to allow a folded over stem to weave between the screws and still allow access to the screws to remove or install them. Sorry but the only way to make a low rider work on one of those would be to add another hole and thread that and most folks don't go for the permanent modification.
STR
Hey Steve, howabout a clip that has a hole in the middle that still enables screwing it to the ZT300 series without making new holes.
This is cause the clips that come with them is the least liked part in my opinion.
Yeah I had my fill of those with the Spyderco barrel clips and just decided then it was not something I'd want to do repeatedly. Its also another matter of once you drill the hole then you have to hit the fold over just right so that when you do the 180 the hole is sitting over the hole as you envision and usually it does not so you end up with a situation where it just looks off and sloppily done.
STR
How about a Chicago screw through the lanyard hole instead of a new hole? I'd get a couple for the 0300 and the 0350.
