- May 12, 2014
I want to sharpen a ZT 0770CF on a sharpmaker using the medium, fine and ultra fine stones. is this system capable of doing the trick? I am a newbie sharpener and this will be my first time trying to sharpen Elmax.
To properly sharpen it on such a device you should reprofile it to the right angle that device uses so you fully apex the blade. The medium grit may not be as aggressive as you like so you can get some wet/dry sandpaper and rubber band it onto it and use it like normal to reprofile it. If you don't it will still work but just take a while longer to get good results as you reprofile it.
