Here's my experience, and I've owned two 25's..
I can flick mine open just with the movement of my thumb, or, I seat the stud right in my first joint from the tip, and with a circular motion, open the knife. Works perfect both ways every time. It DID require a break in period. The first 25 I broke in by cycling the knife open and closed til my thumb was sore. My second one, I told myself I ain't doing that again. So I disassembled it, and polished the washers (only the sides that contacted the blade) with polishing/rubbing compound and a piece of leather (taken from an old Redwing boot). I put a dab of compound on the leather (rough side) and worked it around to the size of a silver dollar. Using my fingertip or thumb, I worked the washer into the leather using a steady circular motion. After about a minute of this, the washer will be polished to a nice mirror finish. Reassemble the knife, and adjust the pivot to it's "sweet spot" just to where there's no side to side play of the pivot. Then I hold the knife parallel to the ground while open, and depress the lockbar. If the blade freely swings downward due to gravity, I'm happy. Believe me, polishing the washers will immediately give the knife a different feel. VERY smooth! That was my break in period for my second one. I also use Nano Oil for lube, as grease tends to feel as if it creates more friction than oil.
Everyone has their own way, and I'm sure folks will say mine is wrong, or voids warranty, or whatever. But I honestly could NOT be happier with what I have done. In my opinion, this should be done at the factory, but to each his own, right?
It might be worth noting, polishing doesn't remove any metal like sanding does. If it does, it's negligible. So I never worry about the knife no longer being within factory tolerances. If anything, they're even tighter
