Given that it's differentially hardened that shold work nicely.Drill it for a thumb stud and you won't have to flick it open.
If you did deepen the fullers that might also provide enough purchase to one hand it.
If you did your next bolster out of medium or high carbon you could harden and draw them to spri g temper and that oughta do it.
I was planning on spring tempering the lockbar hoping that might absorb some shock. Is that what you mean by bolster? Sorry my folder terminology aint quite there yet I dont want to harden it too much or im afraid it may break at the pin hole. Its completely annealed right now. Bookies sardine can temper seems to work pretty dang good at evenly tempering so I may try that. I ordered some 1/8" pivot pins that use 2-56 screws and are hardened so im thinking I could use flat (countersunk) screws through the brass to mount them. That would spread the load out a bit and maybe help as well.
Fullers? You mean sword of shiva fullers right? not Chirras? I aint messin with no chirras yet
Yep that would scare me too. no doubt JW can do it second nature but i aint that good...yetYes, he means deepening the Chirra to reduce the weight of the blade and reducing the shock. I personally, wouldn't go that route.
I actually like the way ZT does it on the 0350. The thumb stud also acts as a stop pin when opened. But that uses the speedsafe system, so opening is spring assisted. With a heavy blade like this, that solution may not work. But a properly placed thumb stud should aid opening without the need to flick it open.
The trick is getting the lockbar to rest in the same place open and closed so it dont stick out obtrusively in either position. It means the geometry of the tang shape (where the lockbar locking tab rides) must be precision cut. Pretty dang tricky and hats off to these guys that do it custom.
... I meant the placement of the thumbstud to act as a stop pin.....
No worries. Thats what the pause and mute button is forBTW, you don't want to listen too much to cutlerylover. It'll rot your brain with all the nonsense and conjecture.
Oooo! Thats an awesome tool phill. I could probably just rig up a dial indicator and make something like that. Khul Thul! Thats where im getting my parts from btw. Ive had an account with them for many years.The trick is using a rise/fall indicator.
