- Feb 3, 2001
Thanks, Blue Sky, I might try doing it that way at some point. I'm not sure I see an advantage, though.If you insert an image directly into a post, it will not show as part of your media. Where it goes and how you can find it again later (outside of revisiting that post) is unknown at this point as far as I can see. No one else seems to know either.
If you first create an album and then load images into it, you can then insert them into a post, and then find them again anytime using the "my media" tab. I have used both of these methods, and that is how it has worked.
So, if you want to have easy access and control of the images you upload here, I suggest you use the album method.
Heres a pic from my album:
View media item 1266
I'm going to bump this one last time, because I'm stubborn that way. @SparkI have my pictures organized in folders on my computer, and it's very easy to find the one I want to post and then just drag or copy it into my post. I just want to make sure I don't reach some storage limit doing it that way, and then have to make room by going through my post history and deleting pictures one at a time.
I did it, and then tried to remember what I'd just done, so I figured I might miss a step or two.Thanks, r8shell. I used your idea and was able to create an album. There's an in-between step that you didn't mention. You have to click the radio button to add media to album, and then you see the album drop-list, which includes "new album" as a choice. That gets you to a dialog where you can add an album and give it a unique name.
I haven't tried using the album yet, but that's next. The album currently displays with the name and (0) next to it, which I assume will increase with every image that I add to the album. That still leaves open the question of how to tell when the album is getting full.
I remain astonished that no one from "management" of bladeforums has bothered to answer the questions being discussed here. I am very disappointed in this......
