A new one on me.
& today a hammer turns up!
That's a nice cross-pein there. It appears to've never been dressed,that or it maybe was used only for some very light/delicate work. With that chip in the face ground some it'd make a very decent hammer...(and i'd soften/radius/chamfer the facets of that pein as well too).
It's like when I get a new car and from that point on begin noticing how many of those cars there are being driven that I'd never noticed before. It can be a bit deflating depending on how deeply you identify with things.
You'd want to confirm it on your own but it could be that the saw is for butchering.
It may take some time and effort , but this Plane can be saved , although it may show a few battle scars , but it will most probably still work fine.Lie Nielson.......
Not very Axe like but I know there are a fair few woodworkers here.
Not sure if I can save it but it'll be quite a paperweight if not!
Some folks don't deserve nice tools.. thought I don't know the history & I'm sure it wasn't intentional.
You’ll bring it back, probably better than new.
Parker
This is a good tool , if it was mine , I would make the effort.
Best of luck with this project.
If the pitting on the sole is not too bad around the throat opening , and you can flatten the sole and sides uniformly , (don't try to remove all the pitting) , the plane should still work well , some pitting does not really matter elsewhere on the sole.Thanks, but these are super well finished new, so I doubt it! . They were (are) probably the most expensive planes....
It was found in amongst lots of stuff in a tool box that might have been in a flood then left....
The pitting is really deep in places, there is only so much iron that can be removed from the sole before it adversely affects the throat opening though it is adjustable so that helps a tiny bit, as you say it'll have some battle scars as it'll be impossible to remove all the pits.
Anyway I'll give it a go, there's nothing to lose!
The cutting iron has been worn out and will have to be replaced , I will either have to make a new cutting iron from scratch, or else adapt a new spokeshave cutting iron to the body.
