- May 25, 2007
magpul od green items,spike tactical buffer & spring,timberwolf lpk,magpul single sling ring/end plate. I have my eye on a Colt or DD carbine upper
Hey can anyone recommend a good wrench for removing a very well-staked castle nut from my receiver extension that won't break the bank? This is going to hopefully be a one-time deal. if it has a fitting for tightening a rifle buffer tube, even better. Gracias!
I used Krylon on a few. When they wear after use, or I want to change the pattern colors for the season it is an easy application. Not expensive, and I'm not worried about making it look all cool, pretty and digitalized. I'm breaking up the outline. That's what's fun is using vegetation as stencils,tweaking, etc...
I want to try the Aervoe paints... Heard they are better than Krylon.
Here's a little overview I did of the AR Multitasker multitool and the TUBE.
Great stuff for us AR lovers!
http://www.bladeforums.com/forums/showthread.php?p=8889637#post8889637
I'm planning on a 16" flattop, 1in9 twist chrome lined, M4 feedramp with at least one rail for my light.
Took me over a month of research to decide on my lower so might be awhile for the upper.
Parts kit is Del-ton as well. From all I've read, Del-Ton has great products and service so I went with them. More for the quality than the low prices.
The mastermind behind the multitasker line is a good friend of mine. Glad to see you like his products. He is setting the bar high in the multitool industry.
