Two ULZIO R-1 Flashlights
Feedback: +10 / =0 / -0
I have 2 BNIB ULZIO R-1 flashlights for trade. I'm interested in plain edge, folding knives. Open to any suggestions.
I bought 3 of these, but decided to only keep one. I have been more than pleased with it so far. I can reply to any questions through this thread or through my email: edgar_egg@hotmail.com make the tittle say ULZIO R1 for me to not loose you're email.
Here is the best description of the ULZIO R-1 I have found:
Rapid Ring Mode Selector
As the ultimate tactical illumination tool, the Ulzio R-1 is designed around the revolutionary, easy to use, magnetic rapid ring mode selector. A standard reverse clickie tail cap switch provides basic on-off operation while the separate rapid ring selector allows the operator to quickly and easily change between high, medium, low, tactical strobe or SOS lighting modes. The internal switching circuit is magnetically controlled by the external rapid ring and therefore completely isolated from the elements making this a truly water-resistant all-weather flashlight. While many multi-mode flashlights simply cycle through the modes or require complicated button press patterns to change modes, the rapid ring is the fastest and easiest mode selector available.
Hybrid Reflector Assembly
The large and highly polished reflector provides the best of both worlds when it comes to beam patterns. The broad head ensures the light has a highly focused and intense center hot-spot which can reach out several hundred meters while also creating ample spill for illuminating close broad areas.
Long Term Savings - Powerful Options
Most high-end flashlights are powered by expensive disposable CR123a lithium-ion batteries. The G-11 on the other hand comes with a quality 18650 lithium-ion battery (the same that is found in most laptop battery packs) that can be charged several hundred times before needing to be replaced. The included charger takes approximately 4 hours to fully charge the battery from empty. Not only will you save money on batteries but you'll get a much better run-time. The 18650 battery can power the light on low mode for over 8 hours.
Quality Construction and Design
A USA made CREE R2 LED and digitally regulated driver are at the heart of this light and provide the ideal amount of light with limited heat build-up. The CREE R2 LED will never need replacing and is the perfect compromise of power conserving efficiency and bright overall output. These critical components are protected by the triple anodized black body which is accented with silver anodized strike bezel and rapid ring selector. Finally, o-rings at the bezel, head and tail cap give this an impressive IP 44 water-resistance rating. Simply put, this is one light you’ll have for decades of use.
Includes
- Ulzio R-1 Flashlight
- 18650 Rechargeable Battery
- Charger and Power Cord
- Gift Box
Dimensions
7.1" Long x 2.2" Head Diameter x 0.9" Body Diameter (works with most 1” flashlight mounts)
