- Dec 6, 2007
Do the scales swap?
You sparked my curiosity... it's clear the M18 scales are similar but not exact clones...let's find out...
The first 5ish m18s did use becker handles. However all the handles since then he made something based off the becker handle it's a bit longer so no the scales don't swap.
Actually... turns out mine swapped out perfectly. Even the hardware is the same and the hole alignment is exact. The only distinguishing difference is the M18 scales are slightly larger overall and are contoured a bit differently from the Ka-Bar micarta scales.
Pictures don't lie (usually
Below with the L/H scales swapped attached with original hardware of each (though they're the same and I tested it; the screws & nuts are interchangeable.) [After a closer examination I noticed the hardware on the M18 has one difference - the center bolt is about 1/8" longer than the others; naturally due to the palm swell of the Hunt scales.]
Another side by side comparison: BK-9=Left, M18=Right.
This shot shows the slightly smaller Ka-Bar scale attached to the opposite M18 scale to better show the relative dimensions.
Technically they aren't perfectly interchangeable but practically, if one wanted to for some reason, it can be done. I could possibly see using Ka-Bar scales on the M18- the slightly smaller size exposes more of the pommel and narrows the grip width a little and they fit well enough that the tang doesn't bite into the hand. Likewise one could put the larger scales on the 9 but then you're loosing a bit of it's exposed pommel and broadening the grip width some.
Personally, I like 'em in their original configurations- I have no desire to change them.
