SOLD 🔥 Half Face Blades SHPOS Gen 3 - New🔥
hwesley
Feedback: +142 / =0 / -0
From the web:
8" overall open, 4 7/8ths" overall closed, 3" blade, 5/8ths" thick with pocket clip
Body - Machined solid billet 6AL-4V Titanium Type 2 anodizing. The body is a true monolithic frame which eliminates the need for backspacers, stand offs or additional hardware while gaining strength and rigidity.
Blade – S45VN stainless steel (58-59 RHC) with a proprietary heat treat to bond with a nitride coating (62 RHC).
Lock Up – Tapered button lock and bushing coated with nitride finish to wear evenly with the blade. System willll wear “in” with use, not wear “out”. The longer the blade is used, the tighter the lock up will get.
Pivot System – Dual, sealed roller bearings press fit into the frame. Pivot pin is captive to the blade and bearings eliminating all play in lock up and close. Dual bearing pivot system maximizes stability, while reducing friction in opening of blade.
From the web:
For the first time ever, ZT is using a black-oxide BlackWash finish with its classic tiger stripe pattern. The 0308BLKTS offers a beefy 3.7-inch tiger stripe blade with premium CPM 20CV blade steel. The handle features black G10 on the front scale with a titanium back. Both the front and back are heavily 3D machined for an ultra-secure grip. The 7/32-inch solid pivot includes a custom nut that enables it to be adjusted in the field with a 1/2-inch wrench.
20250519_143356.jpg20250519_143403.jpg20250519_143225.jpg20250519_143820.jpg20250519_143456.jpg
SOLD
