What always messed me up is thinking about how you could divide the distance between two objects in half and never arrive at zero, ergo they would never touch.
Math and science were never my strong suits.
but you can not buy exactly 1 gallon.
It's not a difficult concept. Let's say that 1 gallon of gas costs $3.29 9/10. Since there is no 9/10 cent coin, you have to either buy a little more or a little less, but you can not buy exactly 1 gallon.
You should have stopped at pie. Of course you can buy exactly one gallon of gasoline... It is the bill that will be rounded not the quantity of gas. Btw, grocery stores do the same thing - and they always round in their favor.
You should try theoretical physics + laser physics + modern optics + solid state physics + quantum mechanics. Add a little dash of national security ... even my mother won't talk to me.
If she were still alive.
it might be better to think about it abstractly, you have 1 cup of water and you pour equal amounts into 3 cups, each cup has 1/3, you know that 1/3 = .333333333...etc but if you put all the cups together you get 1
That appears to work when you are being practical. However when you think about it deeper, technically you cannot separate anything into 3 equal parts. You can get close but not exact.
You would end up with .33, .33, .34 (doesn't matter how many decimal places you go they will only be equal when you reach infinity - good luck getting there)
Edit: I shouldn't have said you can't divide "anything" into 3 = parts. Obviously you can take a 3" string and divide it into 3 1" peices. Let's just stick to water for the example.
Water seems to be a more divisible substance than a string with an inconstant number of particles for equal given lengths. You can divide a glass of water in 3 equal parts if you have an amount with a total # of molecules that is divisible by 3 and a measuring system that can count the individual molecules. You would also have to eliminate all evaporation or keep it at a constant between the 3 glasses.
Also, infinite doesn't exist. The idea does, the actual quantity doesn't.
Root cause of the problem, 1/3 != .333333333333... go on as long as you want. Its an approximation. Also, infinite doesn't exist. The idea does, the actual quantity doesn't.
Edit: I shouldn't have said you can't divide "anything" into 3 = parts. Obviously you can take a 3" string and divide it intopiecespeices. Let's just stick to water for the example.
If you people have this much time to think about this mind bending stuff..................you need more knives to play with!!!
Without infinity most grad students and graduates in science, engineering and math would be out of school/jobs. Converging limits, integration and many equations used for those fields that are then turned into practical items/work/designs may require these theories.
True, but have you ever seen a bridge that is infinity feet long? Or a building infinity feet tall? They're called imaginary/complex numbers for a reason. They don't actually exist, only the idea does.
Science sure has gotten colorful lately.
