My knowledge in this area is slight and , like you, would lke to understand this better. Fredfitzo said:It sounds good to me, Fred. I misunderstood what you were saying regarding the freezer.
How much chilling a blade affects it will depend on the specific martensite finish for that blade. With stainless, and I suspect most air-hardening steels, that temp is way below ambient. One thing I've never run across is data that actually graph the sub-ambient conversion of retained austenite versus time and temp. I have asked the question several times and never gotten a good answer: is it an absolute temp thing, or is it a rate phenomenon, such that a longer time at a higher temp achieves the same thing? This is getting into minutae of HT that are beyond my meager knowledge. If anyone has a source, I'd enjoy reading it.
Protactical said:I've had O1 blades kicking around for days before I put them in the oven. They were all stock removal pieces, and did fine. I find O1 is pretty forgiving.
You can increase the performance of your torch with a brick, just look up "brick forge". I suspect that is more effective than MAPP.
Hi Mete, Assuming you performed all the austenitizing work properly; correct temperature, soak time per specified steel, use of the right quenchant at correct temp. does it then make sence to continue the cooling, after hardening, into the sub ambient temp[cryo] before you temper. Or would this increase the odds of the blade cracking or distorting under the retained stress of hardening. Does this come under the heading of a trade off? you can't have it all. If the double tempering stabilizes the RA so it will not convert to martensite what is the purpose of cryo after tempering or the freezer treatment between tempering cycles? Thanks Fredmete said:Fred, as you go through the cooling from Ms to Mf you continue to convert to more martensite and on some of the TTT diagrams there are lines showing M10, M50, M90 lines etc.[that is 10% conversion, 50% conversion etc] However it's more complex than that .Assume the more complex the alloy the more retained austenite no matter what you do with it. Also some of the tool steels show a marked difference in retained austenite vs austenitizing temperature .Too high an austenitizing temperature and you could end up with maybe 15% RA !! Freezing will convert some of the RA but don't expect to correct poor heat treating with cryo !!! It's all very dependant on composition and the details of heat treating .BTW some RA is beneficial in some cases and of course double tempering stabilizes remaining RA so it won't convert !
correct Kricket:thumbup:kricket said:If your doing stock removal, the steel isn't put through the same stresses that are introduced during forging. It's a lot different when you beat a blade out on an anvil. Or at least thats what I think....I could be wrong and if I am someone will set me straight.
That shines some light on it for me. Thanks for the clarification Mete. :thumbup: Fredmete said:Yes Fred there are trade-offs. Those steels that are more prone to cracking should be tempered the minute the blade gets to quenchant temperature ....Looking at a more complex steel such as the S30V, 154CM etc - we quench, maybe snap temper for safety [300-350F] ,freeze, double temper. The freezing converts more of the RA to martensite , the double temper then stabilizes the remaining RA so it won't transform over time.....The snap temper temperature is such that it doesn't stabilize the RA. If we raise that temperature to 400F , it will stabilize the RA !!...It's all logical -the right times, temperatures and sequence get the results !
