hey all, having some issues with my 01 not getting hard after quench.
i quenched 10 blades yesterday
*all blades are forged in a charcoal forge.
*used an evenheat oven with a brand new thermocouple (as i've had this issue recently and suspected a wrong reading). i did an oven test using a magnet and it seemed to only be about a 5-10 degree difference between non magnetic and what the oven read.
*normalized at 1400 for 5 min, then 1200 for another 3, then air cooled to room temp
*brought to 1550 and at 10 minutes, each blade brought out and checked for straightness, one at a time, hammered slightly if needed, then put back in for another 10 minute (minimum) soak
*quenched in what the receipt said was "138 degree quench oil" bought expressly for 01 quenching. it's very old oil. 3 years or so? in an old army ammo box. old enough to have a small layer of sloughed decarb on the bottom. oil temp was always between 120 and 150 degrees.
file checked them all and the file grabbed on each one.
i didn't check for decarb layer as the blades are forged pretty thin as it is. i guess this could be it, but have not had this issue in the past using the same forumula.
due to the forging could i have burned all the carbon up? these blades have been somewhat lost in the shuffle and i had no idea what has been done to them in the past so decided to renormalize and harden again. so potentially, these all could have gone through the entire process (including tempering) already.
could the oil be too old?
i'm at a loss. thanks in advance for your input.
