i have tried a limited number of steels, but assuming good heat treat i think that either one will work fine for what you have in mind based on description.
i have a chopper in S7 that i have tried breaking and failed. it is only 1/8" thick x 1.75" wide x 12" long (blade, 18" overall). powerhouse of a chopper and pretty much indestructible.
i have read that 1095 is tricky to heat treat, because it is a shallow hardening steel. but in sizes used in knives this isn't really a factor unless you are dealing with ridiculously thick blades (3/4" and up). i would say if you are having it made go with whatever the maker feels most comfortable with. if you are making it go with the least complicated option to start with.
something that i like about the air hardening steels (S7, A2, etc) is that all you have to do is get them to temp and leave them there for a while, then take them out and put them in a fancy clamp ("heatsink"-though this step is not necessary) and you have your hardness. you don't have variables like different quenching mediums and different temps of quenching mediums. with liquid quenching steels you have to be more on the ball with it. with air hardening it almost does all the work for you.
of course with air hardening steels there is alot of trouble differentially tempering (i don't recall ever seeing it done), and i don't think i've ever seen a hamon on an air hardening steel, if that is a factor at all.
Edited to add-in regard to cost, S7 is kinda pricey, i want to say about double what you would pay for O1 off the top of my head. so its a little expensive. but when you consider that depending on how you buy it you can make anywhere from 1 to a dozen or more blades from one piece for the same price, its not too bad.
