rodriguez7
Gila wilderness knife works
- Feb 1, 2009
Anyone know what the hardness on the 0560 blade is? Anyone test the edge retention?
Don't know the hardness. It quit shaving pretty fast, though, with only what I would call light duty. It is still VERY toothy, but it would only scrape hair at best. Spyderco white ceramic didn't do quite what I wanted for it, so I tried their brown ceramic. That did the trick, toothy, but back to shaving.
It does OK, but I would never recommend anyone buy the 560 for the ELMAX. I've yet to see a super-steel live up to the hype. The 560 is EASILY worth the money, but not based solely on the steel. Based on the workmanship and materials, though, it is tops.
Elmax sharpens like a high grade carbon steel, yet it is stainless. It does what it does better than just about any steel on the market.
ELMAX isn't a "super" steel because of its edge retention. So you judging the steel on that merit would of course leave you disappointed. ELMAX's claim to fame is toughness, and its edge retention is just slightly better than S30V.
You must use a lot of CPM M4 or S125V.If Elmax has better abrasion resistance than S30V, that means that it has better abrasion resistance than the vast majority of commonly used knife steels. With that said, i suspect that Elmax is tough only in comparison to other stainless steels and pales in comparison to stuff like 3V or L6. The best numbers that I have ever seen even for a nitrogen steel that was true stainless (not INFI) was maybe 60-65% as tough as the typical numbers you see from 3V.
Let's put it this way... I would be overjoyed to get the performance of my 560 if it had the same steel as my 550. ELMAX may be the best thing since sliced bread, but I'm not seeing the benefit over the S35VN of my 550.
The benefit is toughness and ease of sharpening. Of course S35VN is fairly tough to begin with, but it can't hang with ELMAX.
And I'm still failing to see your point?
Besides that, ELMAX has not been easier for me to sharpen than S35VN.
There is no point, just giving you info. Just as an FYI, "ease of sharpening" is very subjective. Your singular experience doesn't negate chemistry and physics.![]()
