1/4" or 3/16" blades
shigawire4sure
Im curious what the census is on blade thicknesses is for "the one blade" theory. Do most prefer one over the other? Why? Personally most of my "just one" blades are 1/4" but I'm starting to question the bennefit.Any input? Paricullarly 3/16" vs 1/4".
3/16! 1/4" is good for heavy choppers, but for cutting, 1/8"-3/16" because we aren't going to do any prying, are we?
For me either 3/16" or 1/4" is best for large camp knives, 7 or 8 inch blades where splitting and chopping may be involved. 3/16" is good for 5 to 6 inch field knives. For fine work and big game prep, I like no more then 5/32" with 1/8" as the best choice.
Scott
If my "one" knife had a blade of less than 5" I would prefer 3/16 - over 5" and I would want 1/4"
3/16" for around a 4" blade or shorter; 1/4" or 5/16" for longer blades.:thumbup:
I like thicker blades; that's just my personal preference. (I don't want to even have to think about "babying" my knives.) ;)
3/16" is more than enough. I have a few that are thicker, but only because I liked the blades and they didn't come 3/16".
Definitely 1/4" for my "one knife", which under almost all conditions will be a big chopper. That extra 1/16" makes for a tougher knife, which is exactly what I want when that's all I'm carrying.
3/16" is about my favorite, but 1/4" can be fine as long as the grind is right. I do believe a lot depends on th grind.
I should have mentioned the grind preference, mine being either full flat or scandi(saber) though I do like full convex as well(other than a Bravo1/BRKT I find them hard to find though).
Like most here, 1/4" only for a big boy. 3/16" to 1/8" would be the ideal belt knife usually. The kabar bowie is 1/4" and is one of my favorite blades, though. The full flat grind allows it to keep a very good slicing edge.
It's all about the grind.
1/8" is best.
3/16" is as thick as I like to go. Thats alot of steel to swing. If you break a knife 3/16" thick you are probably chopping concrete or metal..
I think 3/16th is plenty on a sub 5" knife. My favorite 5+" knife is the Busse SFNO which is .220" (which I believe is 7/32 happily right between 3/16 and 1/4). I can't imagine anything breaking it either.
Folks do some serious chopping with machetes at, what?, under 1/8".
Real "mountain men" were happy with 1/8" or less.
3/16" should do unless the knife is a dedicated, axe substitute.
