- May 21, 2000
Does anyone here grind using a 1" contact wheel? If so, do you note any increase in control or precision? Thanks!
EZ, are you referring to a 1" diameter wheel or a 1" wide wheel?
--nathan
1" wide wheels ROCK! I do all my grinding on them. I buy them from BADER.
With a belt splitter (Midwest Knifemaker's Supply) you can buy 2" wide belts and split them. You can actually use-up (wear out) the entire surface of a 1" wide belt uniformly and there is cost savings to be had.
Control is great as you are able to focus on a smaller width when grinding.
I highly recommend them.
RJ
