sodak said:
I'll probably keep sharpening at the same bevel through at least 3 more cycles, and if I'm still getting damage, put on a 15 microbevel and do a bunch more cutting with that.
I thought the Calypso Jr. was at 15 per side already? Or is this in reference to the D2 blades?
CMSpeedy said:
I got some slight chipping today after cutting cardboard boxes.
What size? Roughly how many meters of cardboard was cut? Less than 10, more than a 100?
Should I put it on the Sharpmaker at 15 degrees to remove it. This will also put a bigger bevel at 15 which may help with the chipping. What do you guys think?
Resharpening is likely to eliminate the problem, increasing the angle would likely help here as well. However the steel should not visibly get damaged cutting cardboard. You don't want to get into the habit of thickening edges to compensate for defective steel, assuming you are not hitting inclusions in the cardboard or cracking it through hardened epoxy. But even the latter seems difficult for me to accept because I have done hard plastic cutting with such profiles and heavy cutting of plywood and the edge will not get visibly damaged.
My blade is also getting very ugly looking. A 10 degree angle on a flat ground endura 4 produces a HUGE bevel. It goes almost all the way across the primary.
Yes, the primary is only a couple of degrees more acute.
I am thinking about sending it in to have the primary reground thinner by a few degrees.
In general you should always get the primary reground rather than reduce the edge angle. However as a user it is very difficult to do one and easy to do the other which is why people regrind edges.
Before you jump to the conclusion that the blade is defective, just see if the problem is removed with sharpening. Many times the initial edge on knives is made of weakened steel and removing it with sharpening makes the edge much more durable.
gud4u said:
Every test I've made indicates that for hardwood-slicing with the steels I've tested, a final edge taper of 30 degrees provides adequate strength, whether it's applied as two 15 degree bevels, compound 10/15 bevels or convexed bevels.
The only reason I use 10 degree main bevels is for the general improved slicing performance - which has nothing to do with edge strength.
Yes, and yes. The problem is the posts like yours are vastly overshouted with makers constantly promoting "convexing" edges to make them more durable/cut better. The willingless of people to accept without critical thought always leads to the ability of misinformation to propogate rapidly. Ironically this is one thing the Bladeforums user base constantly complaints about with the non-knife people being "sheep" and just accepting the ideas of the goverment about the dangers of knife use/carry. The misinformation about convex edges will continue until a maker like Cashen takes a very public stance and tells people to look at the cross section and not the curvature.
db said:
Isn’t the convex curvature what effects the edge cross section?
A convex bevel simply means the curvature is above zero which is a flat bevel if it is negative then it is a hollow bevel. The bevel applied by the Edge Pro stones is going to be convex simply because the stones wear. Now it isn't very convex, the radius of the arc is very large, but it isn't perfectly flat. The problem is the common implication that the curvature itself is solving the problem which usually leads to some discussion (not here) of very incorrect physics to try and support this arguement. I could easily apply a convex bevel to a knife and make the edge stronger and cut worse, or weaker and cut better or even stronger and cut better or weaker and cut worse depending on how I applied the convex bevel.
-Cliff
