10" integral chef WIP.
Well, I had a nice 10" integral chef forged out and ground the other day- and warped it in the quench, then ultimately cracked the edge. I had ground it too thin prior to HT. So, I had to re forge the blade for the customer. I thought this time I'd document the process with pics.
When I first started using my Little Giant, I noticed that there is not a wealth of information on the web about the specifics of using them in blade smithing. This is me trying to contribute. I’ve forged a good few of these with no mechanical help, and the hammer is a godsend for integrals, especially with some basic tooling.
Here's the first blade. It's been soft back drawn, prior to the last straightening attempt.
Here's the edge. You can see that bad ripple warp caused by an edge too thin for austenization. I'm now just using the blade for a rough template for the new one. Later I'll probably cut the crack out of the edge and re-shape it into a knife for my wife's cafe.
First, I select a 2” roller bearing out of my stash. Then, I cut a handle out of some #4 rebar, about 24" long. I do prefer a somewhat heavier handle, but I just had this on hand. I bevel the end of the rebar, to get full penetration with the weld.
I set a firebrick on the anvil for a welding table, and clip the bearing into the ground lead from my AC arc welder. I set up the torch on my anvil torch stand, light it, and use the cutting head as a small rosebud to preheat the bearing. You get better penetration with your weld into the bearing metal this way, and the weld takes like butter without a cold start. I don't preheat the rebar end, as I find this leads to undercutting and a weakened handle.
Using 6013 at about 120 amps, I weld it up. Ugly but strong.
I had the forge preheating while prepping the bearing. Into the forge with it. I use my big blown forge for this work.
With the bearing probably an even 1800 degrees, I throw it on the power hammer. The first heat blocks it out roughly solid.
The second heat brings it down to about 1-1/4" square.
The third heat brings it to the target dimension of 1" square, and finishes by truing and flattening the sides, parallel to the dies.
Next I begin to draw out and taper the end of the bar. I forge it thinner toward the tip, thicker toward the planned heel as I need that steel there to draw out the width; on this particular knife the heel needs to be 2-3/8” wide, which presents a challenge to efficiently forge right next to the 3/4” tall bolster.
Using light blows with the hammer, feathering the clutch, I forge a point into the tip. It's much easier to start this early, as a point is much harder to forge on tall, thin stock. The trick here is to hammer lightly while smoothly drawing the stock backwards. Stopping the motion at any point can lead to shoulders you don’t want in the profile.
The bottom die is a very mild drawing shape, and the top die, while slightly more aggressive, is a mild drawing shape as well. This is a good combination for general forging; there are no abrupt corners to form cold shuts or nicks in your blade. It is a bit more forgiving when using hand held tooling as well, tending not to knock the tools around sharply if they are held slightly misaligned.
I take an educated guess at roughly where the heel of the blade will drop from the bolster. I use a large spring fuller to forge in a double shoulder here. I only go down to about 1/2" thickness, saving the rest for the more accurate and correctly shaped guillotine fuller.
Using the guillotine fuller, which fits into the hardy hoe of the anvil and can be seen in the background, I finish fullering the shoulder at the front of the bolster down to about 1/4" finished thickness. I built this guillotine myself, with heavy angle iron, square stock, and plate steel. It has dies made from leaf spring, and a mild steel striking surface welded to the top die.
Going back to the power hammer, I use a fairly aggressive top fuller to selectively spread the steel wider at and near the heel. This saves a lot of cross peen work by hand.
As a close-up shows, this is a rough process and tends to force the metal equally to each side. This needs to be corrected. I use another hammer tool for this- essentially it’s a short block of 1.5” square steel welded to a handle, with the corners softened a little. I use it as a top hammer to set the bolster down at the heel, bringing the spine and the top of the bolster more or less in line. This is repeated as necessary during forging.
I spend a heat forging parallel to the dies, widening the main body of the blade. The top fuller is not necessary here.
Back to the heel area with the top fuller again.
Back to setting the bolster in line with the spine again.
Here’s a shot of the profile as formed on the hammer. Pretty rough yet, but most of the steel has been pushed where it needs to go, and the rest can be done by hand in a couple of heats.
I do some tuning and flattening near the heel.
I hang the heel over the anvil edge, and use a half-face blow on the spine and bolster to even up the spine and get rid of that hump near the bolster.
I use a set hammer on the bottom of the bolster, with the blade edge up, to further set the bolster correctly in line with the blade.
I correct the resultant bulges in the spine, flattening the blade again. I use a mild cross peen to further widen the blade right at the heel.
The profile now being smooth and correctly sized, I adjust the overall shape of the profile by “shwocking” (a term I believe Wayne Goddard coined) the blade on a stump with a hollowed top. This allows me to bend things and change the profile of the blade without making any hammer marks in the spine or edge. I’m using a dead blow hammer here.
The profile is good for now. It’s time to cut it off the bar, and draw the tang.
I get the steel nice and hot, then cut it off of the bar with firm blows over the cutoff hardy, using a 6 lb. hammer. A heavy hammer and heavy, deliberate blows help a lot here.
With the stock nicked almost through all around, I bend it apart with a pair of tongs. Hmm, not much of a stub there, seemingly.
I heat the tang/bolster stub and insert it into the guillotine fuller. This is another area where a 6 lb. hammer and some slow, heavy blows will help. The guillotine fuller works much better than a spring or “godzilla” type fuller, for most tasks.
The resulting shouldered tang stub.
I bring the heated tang end over the power hammer, and draw it out. It takes me two heats to do a nice job.
I finish forging the tang true by hand.
Here’s the finished profile, from the forge. Everything has been left significantly thicker than the finished knife will be, both to assure decarb removal in grinding and to give plenty of leeway to remove an accurately ground blade from the surrounding steel.
I normalize the blank...
And after normalizing, I do three sub critical anneals, heating to 1350 or so, air cooling to 1000 or so, a black heat in shadow, then quenching each time. The last time I dry the blade off and set it aside for grinding tomorrow. These thermal cycles approximate a rough spheroidizing of the forged blank, making grinding and drilling much easier and less wasteful of belts; especially with 52100, it works a lot better than wood ash, vermiculite, or leaving it to cool in the forge.
Here is a detail shot of the three main tools used to form this blade on the Little Giant 50. The top fuller is on the left. It’s made of a small roller bearing welded to a mild steel bar.
The square top hammer is in the middle; it’s just mild steel 1.5” stock welded to a handle, then reheated and quenched to add a little toughness. It holds up very well if only used on hot stock.
On the right is a spring fuller. The fuller ends are 1” mild steel round stock, quenched after welding. They are welded to 3/8” x 1” mild flat bar for the spring. Using flat bar for the spring helps the dies not slop sideways under the hammer, and the two cheek plates welded to the spring are guides to further keep the fullers in line.
Stay tuned, grinding shots will be posted soon.
Very Nice Salem! thanks for doing this.
You don't do any In Oven cooling for your anneal?
Very nice man! I use a buddies little giant as well and love it for drawing out large stock but I am still faster with a hammer on smaller details such as tangs and setting the tapers. LOL when I used the drawing dies to swell the edge of the blade down I would dang near lose all my heat just getting set up so I went back to the anvil and figured I would learn on the machine later. Thanks for the post!
Ryan, I don't have an EZ Bake... just a forge quench and oven temper guy right now. I find this works well to get the steel soft.
Ryan, I don't have an EZ Bake... just a forge quench and oven temper guy right now. I find this work well to get the steel soft.
Haha! My easy bake hasn't been so easy, thinking about going back to the forge! Thanks Salem
This is a cool knife wip. I love detailed ones like this. Cant wait to see what you have next.
Simply outstanding!
The amount of learning, hard work and talent going into that knife is just nuts! Very impressive...
Looks great and cool writeup. Makes me wish I had a power hammer, that would be a bear to undertake just with the forearms.
Pretty awesome Salem. That still looks like a lot of work even with a power hammer. I got a slitter and am getting a drift this week to try my hand with Brent Bailey's hammer tutorial. I'm wishing Greg Haile didn't have a butchered hand. I keep picturing you forging those bearings and the DH III W2 cookies by hand. I've never worked bug stock yet but it's gotta be kinda fun. Kinda like the first couple hours chopping wood? Before you start wishing for a logsplitter?
When you get your press going will you set your guillotine aside and use drawing and filleting dies on it or do you enjoy the hand forging still?
I understand time is money though...
Chapter 2.
Ok. I put a dullish 50 grit blaze belt on the 3hp grinder, and begin the profiling process, spine first. I bring the bolster top and spine flush, and define the spine shape further.
I grind the tang profile to the correct shape. I often profile without a work rest- to me a work rest gets in the way more often than not. I tend to use a rest more when working on non-integrals and stock removal projects.
I shape the heel.
I straighten the edge and establish the long flat section typical of a French-style chef knife.
I re-shape the tip a bit- I had forged it a tad too long, a common thing for me.
I shape the spine further. The spine drops most of the way from the bolster to the tip, and I try to get it profiled so there are no awkward angle changes or bulges, just a flowing curve. This happens nicely when profiling vertically on the platen this way.
The rough profile is accomplished.
I grind the sides of the bolsters flat, making sure by eye to keep the surfaces true and parallel with each other.
I use the edge of the belt to define the spine, tang, and underside of the heel as roughly centered in the established bolster.
I grind lengthwise on the platen, with the blade at an angle, to establish a straight edge of even thickness, and a steep starter bevel. This is another area where my grinding has adapted for this type of blade.
I reach my pre-HT edge target thickness of .040".
I use the same process on the spine- taking the spine top edge down to about 1/8" and flat for now, with some distal taper ground in. I refrain from taking the tip down much in thickness until the last steps of bevel grinding; it's just too easy to get it too thin by mistake.
With the spine now flat and even, I establish a starter bevel on it in much the same way as I have at the edge- taking it down to my target spine thickness of .90". I add a little more distal taper. All of these measures are peculiar to turning a rough forging into a thin, wide blade.
Still using the half worn out 50 grit Blaze belt, I rough the majority of the remaining scale from the flats. This saves my sharp belt from wear later. I include here a shot of the push stick I am using for the bevels- a thick piece of walnut, rounded on the back and ground with a lip to hold the spine. A wide push stick face is advisable on a blade 2-3/8" wide.
I move to the Pheer 427- a really nice grinder for flat grinding bevels; it's my dedicated platen machine. With a newish Blaze 50 belt, I begin roughing in the bevels at 120 Hz. The steel rips right off at this speed, and the Pheer is a 2hp so there's plenty of power.
I work the right side bevel up to the spine, leaving plenty along the edge right now for adjustment.
Of course, at some point, I slip and nick my thumb knuckle... not too bad, could have been a lot worse.
I move to roughing in the mark side bevel.
I finish that...
I grind the blade at a near vertical angle on the platen, on both sides, checking for any dips or twist in the blade, getting it truly flat.
A spine shot...
I move back to the 3hp machine and throw on my shop made small wheel arm, with a 3/4" wheel and an older Blaze 50 grit belt.
At a slow speed, I smooth the bolster/heel transition radius, and clean up the bolster/blade flat radii. Note the top view- you want your bolster fronts, like plunge cuts, to match. These areas can alternately be shaped with a large round file, if you do not have a small wheel arm- it's not too much harder to do.
At this point, my camera runs out of batteries for the second time today, so I decide to take a coffee break and eat something. Another tip- if you drink coffee, try to match every cup with a cup of water, to keep your energy up longer. I eat a banana in the morning with my second cup of joe, the potassium helps the body maintain energy levels longer and more evenly as well. This is important for a borderline ADD case like myself; otherwise my brain begins to fry and wander in circles after a few hours at the grinder.
Of course, breakfast is essential with that first cup of coffee- it's the most important meal of the day. I just include these points as they are at least as important for me as any tool in the shop as far as getting the work done. Your mileage may vary.
Stay tuned. Thanks for watching!
...I'm wishing Greg Haile didn't have a butchered hand. I keep picturing you forging those bearings and the DH III W2 cookies by hand. I've never worked bug stock yet but it's gotta be kinda fun. Kinda like the first couple hours chopping wood? Before you start wishing for a logsplitter?
What happened to Greg's hand?
Forging big stock is about how you describe it. If you come over we should do a little striking on a W2 cookie just for fun. It makes you feel burly until your arm starts wanting to fall off.
When I get the press going I'll probably make some straight up integral bolster dies, just to take care of them in one press. A few different widths, maybe. The guillotine will still get used plenty for my non-blade forging projects.
Great looking work so far. Something that thin I imagine it doesnt take more then a little slipup and its back to square one.
Was curious where do you get your bearings, junk yard or online or something.
Salem,
Very nice WIP. Amazing to me how your photos can make it look so easy?
I drink coffee too, but try to stop right after noon. Switch to distilled and filtered brown water after 5.
My Best,
Dozier
