- Feb 24, 2000
I have a 100lb Little Giant Power Hammer. I have had it for over 30 years. Last Winter I noticed the bottom die was sliding around. Several times I removed the die key, replaced the bottom die and replaced the key. Each time I drove the key in, the key kept going in. As long as I hit the key it would continue to slide further in. What I didn't realize was that the dove tail part of the sow block was cracking open.
The sow block is made of cast iron and the original ones were hollow. This caused a weak spot.
Finally I noticed that the sow block had cracked.
I called "The New Little Giant Company in Nebraska. They had a sow block that would fit. The new sow block is solid. It weighed 240lbs.
I needed to get the old sow block out. I tried and tried to drive out the key that held the sow block in place. The power hammer was made in 1946 and the key was really stuck. Then I decided to try my electric jackhammer. Harbor Freight has two sizes and I have the smaller one. I modified one of the bits so it fit in the key way. The jackhammer easily drove the key out.
The rest was easy. I got the new sow block on and replaced the key.
I think all 100lb power hammers have a replaceable sow block, but the old style 25lb hammers do not. If I was to buy a power hammer I think I would want one with a replaceable sow block. If the hammer does not have one and the lower dovetail splits out it would be very hard to repair.
