You are correct - I missed that line on the right side. To get to the inch version just click on the "Inch" at top of page. Good calculatorIt also shows the speed of the belt m/s and RPM for both wheels .
There is a company in Germany that make CBN *endless* belts .2 x 42 40 grit belt is around 270 Euro as I remember , I will need to check E mail for exact price .60 or 80 grit would be much cheap and mandatory sanding with water . I've been thinking about ordering one for a few years now ... but ceramic belts do the job perfectly. I don't know how much longer would last CBN belt .Very little data about them .ESEE has automated grinders. One article claimed 20s per knife. That means jigs and high speed grinders. Probably diamonds with dual grinders.
Depends on the pressure. At low pressure it could go to 100x more. They are made to scrape fast, not grind. Pressure breaks it down. I found data online in favor of them with volume production.I don't know how much longer would last CBN belt .Very little data about them .
I was wrong about priceDepends on the pressure. At low pressure it could go to 100x more. They are made to scrape fast, not grind. Pressure breaks it down. I found data online in favor of them with volume production.
I think that I should go this route , all big wheels ? It will be much more compact . What do you think ? I will also slow down bearing speed .
I was just thinking that. Sure it'll remove steel fast but it'll remove fingers too. At least at that speed you'll be able to grind up the hospital bill with no problem.It's not a 10K "rpm", it's 10k "SFPM" belt speed.
I'd sure hate to bump a knuckle on 36 grit at 10K SFPM! It's be to the bone before you even felt it.
Yes , just like that .
There is seller on Ebay from Poland .....*smart-grinder* I think I will buy two wheels - 200mm - 8" Belt Grinder Contact Wheel Solid Urethane from him and custom make drive wheel with channel in middle for drive rubber belt .
