- Jan 6, 2014
Im looking at buying the atlas 100k burner and using a freon tank as the forge body.
It is ~9.5 inch diameter so with 2inches of kaowool i should be looking at 5.5 inch inside diameter before applying satanite.
How thick do i want to apply the satanite?
The tank is ~13 inches tall so the inside length would be about 9 inches after kaowool and before satanite.
From what ive read this isnt enough btu/ cu inch to reach welding heat.
What do you guys think?
Would i be better of with a different forge body?
I have a couple 7 inch diameter cylinders but that would only leave a 3 inch chamber
And what is the smallest Inside diameter you guys would consider to make medium size damascus billets??
