55). Use the spydie hole to help map out the stars
56). Hang your spyderco of choice (military for me) so that the hole cast a shadow on the ground - then wait an hour or two and use the shadow to find your direction
edit: more explanation on shadow: by using the shadow (on a sunny day of course ) you mark the initial point of the shadow on the ground, then wait a good amount of time and check on it and wherever the shadow is at that time, you mark it and I believe that North is in between the two shadows (south for you aussies)
Hooray we are more than half way there! Seriously, everytime I think we are out of ideas, one of you guys posts something awesome (sharpshooters target and short barreled blowgun lol)
keep em comming! We may even be able to convince sal to put the list in the edge-u-cation section of the spyderco website
60) Use the blade as an emergency piton, bugaboo type blade or even as a carefully placed chock or cam and clip a carabiner to the hole for protection or aid when climbing
61) Range Finder... hold the Spyder hole at arm's length and fill the hole with a 6 ft person and then measure off the distance...now you have a range finder..specific to hole size and your arm's length. Will work open or closed on most Spydies.
67.) can be used as a bore sizer for paintballs, if it will fit through the hole on the para it may be to small to shoot, if it is the same size or barely bigger they will work, if it is a couple millimeters large than the hole then they will probably get stuck or burst in the barrel.
70). Use it to annoy your cat by sticking their tail through the hole to fray their tail and then watch 'em run 'till it falls off (lockback spydies only please, the other stuff may open and cause harm to you or your cat)
71.) Put larger holed spyders on your bicycle axles to act as a washer/spacer.
72.)Open a bunch of spydies (same model) stand em up on the but in a straight line, put bamboo or PVC through the holes, and bam, a larger, more powerful blowgun than mentioned in #49.(Spyde bugs could be good ammo)
