Tai Goo
BANNED
- Apr 7, 2006
And a blade of 1084 would make many more cleaner kills, if you found yourself on such a battlefield.![]()
... only if it didn't snap into pieces first.
Tai,
Kevin and I will square off with pole arms at Ashokan and settle this in a he-manly fashion.....Either that or we will discuss it over Scotch and cigars like intelligent men.
I vote for option #2.
Stacy
Option #2 sounds better for you and maybe for the state of bladesmithing metallurgy but not nearly as fun for the onlookers as a pole arm duel.
Heat treat! Heat treat! It is all in the heat treat!
Kevin, I will bring up an unopened bottle of 10 year old scotch vatted in 1908, which will probably be a disappointment, to open with the gang. And a good 18 year Islay, Lapphroaig, for those who appreciate the finer points of malt and peat. I always have a reasonable cigar or two in the humidor. I'm out of Cubans ( which are usually overrated, anyway) but will bring up two excellent cigars for us to chat over ( and some others for the rest of the guys). Claro or Maduro?
Stacy
Let's say that I wanted to make something like a WWI Enfield Bayonet. It would have a comparatively narrow 17-inch long blade. I want to be able to ram this blade into a door with a 10 pound rifle behind it and be certain that it wouldn't break (bend a bit maybe, but not break). I also want to be able to make 1 million of them cheaply and quickly (as if there is a war on). Assume that chrome is a critical material and unavailable. Would 1045 be a reasonable material? I assume I could find a fairly simple water-based quenching approach. Could I get the blade up to say 50 RC? If I wanted 50 RC would I be better off using something with a bit more carbon?
You may laugh at 50 RC, but that is closer to the norm for some classic combat knives and even some well known American cutlery than 58 RC. http://www.knifemerchant.com/products.asp?manufacturerID=8
Kevin, I thought you said the only way to make a blade stiffer or less stiff was with geometry…
