- Oct 30, 2002
Edro came by the shop today and we heat treated a blade he had of Aldo's 1084. We normalized then heated to 1500, held long enough for everything to equalize, and quenched in Park's 50 at 100 degrees. It came out straight and looking good. The file test passed with flying colors, so I pulled out the handy dandy new (for me) RC tester I picked up the other day.
At first I was reading in the 40's. Ehhh....not good. Then I realized that the tang had been tapered and was preventing an accurate test. I shimmed the piece and was able to get more accurate readings of around 65RC.
First question: what is the expected as-quenched hardness of 1084?
Next: how do you guys test hardness on tapered pieces. I didn't want to test at the flat ricasso and leave a visible mark, so I was testing on the tang which we fully hardened. I know shimming isn't the best way either as it allows flex to occur. What I was thinking was to take a block of steel as an "anvil" and clamp the tang to it so that it is flat against the block. Then, place that anvil in a drill press vice and adjust it so that the tang is perpendicular to the tester. What do you guys do?
Thanks!
--nathan
Thanks!
--nathan
