Joshua Fisher
- Mar 27, 2018
Hoss I was just asking for clarification for what was a very broad statement based off what I knew, I’m familiar with dynamic crystallization I just didn’t know if that would really apply in this scenario. Also I didn’t have a tone, Im here just trying to help same as you. Regardless of if the pattern welding process does help reset and refine the grain that won’t necessarily help someone that just wanted to use this steel for stock removal or forging a simple knife and maybe doesn’t have the ability or tools to use it for pattern welding. I likely won’t have time to test if it would work for pattern welding, keep in mind I’m not employed by Pops and don’t gain anything from running these tests other than trying to help out.Look up dynamic recrystallization.
Larrin did say that forging a knife from bar stock doesn’t do much but that is assuming the starting bar has fine grain.
I also asked if this material would be good for pattern welding which would require quite a bit of reduction.
And, lower your tone with me.
Hoss
