What is your preferred tempering temperature for 1084? I don't have the skill to do the torch method as I've seen others. I'm going to go with the kitchen oven technique! So what temp and what time? Thanks.
Whit- Maybe you know this already, but don't trust the settings on your kitchen oven. Get a thermometer so you know what the actual temp in the oven is.
all good advice given here Whit. do keep in mind that you can select the exact temp within a range of correct temperatures for a particular application, and blade geometry. Oh no! more complications.... for example you might go for the lower temp 375 or so for a hunter,skinner where keeness and edge holding are the most important, and toughness is a lesser consideration. For a thin bladed butcher/slicer, then a higher temp 400 + will let you use a butchers steel to touch it up and use that amazingly keen wire edge for cutting steaks, etc. Its all good, just depends on the aplication. A thin blade might need a higher temp to avoid being fragile at the edge, while a thicker blade with a little beefier edge can be harder with outrisking chipping....etc. I generally try for a compromise temperature of 390 degrees.
