That's gonna be hard to hold temp in a forge running that hot. Your best bet, using what you have, is to quench just after reaching non magnetic, as you want to avoid overheating the steel. Move the blade around within the forge to avoid hot spots and try to get the heat as even as possible. Of course, temperature regulation is critical in heat treating but with a fairly simple steel like 1084, you'll get decent results with what you have. If you plan on expanding to other steels, definitely consider a oven, a temp regulated forge, or send out you blades for heat treatment.
BTW, for sake of clarifying further discussion, the sum of the processes you go through with your steel is "heat treatment." First, you heat the blade, soak at temperature if possible after reaching austenitizing (critical) temperature. This is above non-magnetic (which is also know as the the curie point); how high above non magnetic depends on the steel. After that, you quench in water, oil, or air/aluminum plates (depending on the steel) to form martensite in the steel. This process is typically called "hardening". After that, it's into an oven for a "tempering" process to temper the newly formed martensite. This relieves high internal stresses in the steel in a controlled fashion to make the blade tougher (for instance, impact resistance) while still leaving the blade quite hard. It can also form new martensite, thus requiring a second, even a third temper depending on the steel.
I just wanted to clarify your terminology a bit to allow better discussion in the future. I'm in no way trying to be an ass, and forgive me if all of this is old hat for you.
Have fun!
--nathan
