For 1080, yes. Canola, peanut, ATF, most relatively thin oils. Peanut has a high flash temp, so might be a tad safer and last longer, but you should heat any of these oils to 125°/135°. Much higher in the oil temp, and it will slow the martensite conversion, reduceing the amount of it, and increasing the possibility of pearlite formation in the martensite. The warm oil will reduce the vapor jacket. Move the blade fore, and aft. Never sideways, and start moving it as soon as it is in the oil. Do this maybe 30, to 45 seconds. This will cool the blade to a point that it is still a bit to hot to handle bare handed. Holding the blade with gloves, or a rag, check for warp. You have about three, to five minutes to straighten the warp with hand pressure, before it fully hardens. If you thermocycle the blade before taking it up to quench heat, you should have little, to no warp.
