Pretty much any of the 108X series steels will work about the same for a knife. There are many slight differences in formulations, but 1080,1084,1085,1086 are pretty much the same under the hammer and in the oven.
The 10 denotes that it is a simple carbon steel, the next two numbers are the decimal carbon percentage rating. Understand that the actual carbon percentage may be higher or lower for the same steel grade, depending on manufacturer and use of the steel. Thus 1084,1085,1086 is the usual designation used by many for the whole group. A letter after the 10XX ,such as M, is a suffix that designates a specific alloy blend for a use - such as Machining, Forging, Fine Grain, Modified,etc.
A little manganese allows the grain to be refined, and helps in quenching.Thus, most steels we use have some small amount ( less than 1%) of manganese.
While on this subject ,I would like to point out to any newer makers that the carbon content in steel is in hundredths of a percent. 1084 is .84% carbon, not 84% carbon.It is often said as "84 points of carbon" or "point 84 carbon". It only takes a tiny bit of carbon to interface with all that iron to make the structure we call Martensite ( which is what our blades are made from). The miscellaneous alloy ingredients( manganese, silicon, sulfur, etc.) are usually far greater than the prime alloy - carbon. There is no reason to exceed the amount of carbon needed to fill up all the spaces in the iron matrix, which is .84% carbon. A little more has certain advantages in making a slightly harder blade, but 1.00% carbon is about the usable maximum for simple carbon steels.Get much higher, and the steel won't make a knife.A little lower than the eutectiod (.84% carbon) and it will be tougher, but not as hard. Thus .60% carbon is about the practical lower carbon content for knives.
So, you see, that a change of +/- .15% in the carbon from the "perfect" ratio of .84% carbon is the whole range for knives (in simple steels). Talk about close tolerances. This is why many of us try to explain and encourage new makers to treat the steel with the best methods. Burn out a little carbon in the working of the steel, and it may not make a good blade.
Stainless steels have much more alloy ingredients, and thus often have higher carbon content, but stainless metallurgy is far more complex than simple carbon steels are.
Stacy
