So im not terribly new to the world of knives, though im more attune to knives that dont interfere with future finances...
Anyway i lost my favorite knife last year, being a buck hood punk in 5160. I loved it because it was a tank. The finish wore a bit, the tip chipped (my fault), and putting an edge on it was not the most fun thing, but it made me feel like i had enough knife.
Im in the market for a new knife of similar quality and price point of around $100.00.
Im in between the new Buck GCK Ground Tanto which boasts the same thickness, and 5160 with a cerakote finish. I like its looks, and im thinking it will balance well too.
My other choice is the Kabar Turok knife in 1095 crovan. It has a saber grind (not sure of the grind on the buck). It looks to be a hybrid of survival and tactical ( which i like ).
Now i know the mantra. 1095 had 95% carbon and has better edge retention. 1095 will pit when it rusts.
5160 is a leaf spring steel that has a carbon content between 60 and 70% it has the addition of a small amount of chromium to mitigate pitting, causing the steel to rust evenly and resist pitting.
The steel is usually hardened to 53 to 56 and does not hold an edge as well though you could chop a tree with it. (i can attest to this).
My question is though since the 1095 Kabar uses has been modified with chromium and vandium, would it have similar rust resistant qualities to 5160? If so i might be leaning to the kabar as buck's 5160 was not fun to keep sharp, and ive had a korean war kabar impress the shit out of me. Still dont want knife to break.
Idk, which of the 2 would you choose for medium survival / fighting knife? Keep in mind i have a hatchet and a CRKT Chanceinhell machette 16" for anything super serious. I just like a 5.5 to 6 inch knife around 3/16 to .2 inch thick that can be weilded fast, but still be tough enough that i dont feel the need to baby it. I prob will use it for food prep, maybe fire stick making and ferro rod striking, light to medium battoning, and wear it right side kydex tucked in belt with a zip tie to draw it defensively from a 45 degree forward angle in reverse grip. Want a knife capable of not loosing its tip if forcefully embedded in a loaded ar15 mag.
