Hello All,
A heat treat failure question if I may...I heat treated a knife made out of 1095 and after the quench gave it the file test which concerned me a bit, as it seemed to bite more that I though it should. Having no way to test it, I simply continued to finish it. Since then I purchased a Grizzly hardness tester and used the same ht procedure on a scrap of 1095 from the same bar as the knife. The results were disappointing: ~HRc 39.
My ht procedure was:
Kiln heat to 1475 degrees F and soak for 10 min (3/16 in 1095)
Quench in Parks#50 preheated to ~130F
I then scraped off any scale in a couple of spots and tested the hardness (softness
) on the Grizzly (which was calibrated correctly according to the 3 test blocks).
Any obvious (or otherwise) errors in my procedure?
As always, thank you for any input...
