Below is what I did (yesterday actually), based on reading everything I could. This is my first knife and first attempt at heat treating anything, so take the information for what its worth. :jerkit:
_________________________________________________________________
I did the heat treat last night and as far as I can tell everything went well.
I used the old wood stove that I have in my garage and some charcoal briquettes, along with a few small chucks of wood towards the end when my coals were getting low. The stove has a bout a 4 inch gap under the actual perforated burning surface where the ashes typically fall. I took a piece of copper pipe and capped (read squeezed in the vice) one end and then drilled some 1/4" holes in it. I then hooked this up to small electric air pump that I have and inserted that end of the pipe under the coals. Using intermittant blasts of air, I had no problems getting the blade hot enough. I did two normalizing cycles where I heated to non-magnetic and then let cool to the point where I could handle the blade without gloves. Then on the third time heating, once it got up to non-magnetic I quenched in automatic transmission fluid, which was pre-heated to 130*F.
Afterwards the blade didn't look real pretty, but the Nicholson files I used to profile the blade did not grab on it, so it seems hard enough to me. After a little clean up I did one temper cycle in the oven @ 375-400 for a little more than an hour. I'll probably do another cycle or two before I am done
I guess worth adding is that while in the fire, I kept the blade vertical with the spine down to try to get even heat to both sides, and when quenching I put it in the oil blade first and held it there until cool enough to touch, a couple minutes maybe.
By no means am I claiming that this is the best way to heat treat 1095, but it is the best procedure I could come up with based on what I read here and other places, and what I had available to me. It seemed to work, but the knife is not finished, nor have I sharpened it fully or cut anything with it, aside from whittling some shavings off a paint stick, so I can't really tell you at this point how well it even worked. Follow at your own risk I guess.
