- Apr 24, 2013
Theme & variation on my first pattern from last year. Hard to believe it's just been a year already since I started working on blades, time flies! This is my first one done with 1095 at HRC of about 60 (Bos HT), with a locally grown Ironwood set of scales. LOA is about 9", stainless hardware & gray liner glued with G-Flex epoxy so the grip is about 5/8" thick with 1/4" radius cuts at the edges. Really enjoy the look & feel of Ironwood, but don't enjoy the smell. It's just sanded & buffed out afterwards, with a coat of wax to bring up the color a bit.
This is the first blade I've worked on the grinder after HT, so I was pretty slow & very careful not to heat the blade. Usually I hand-sand, but with the non-stainless blade, it was too thick to leave for an edge to sharpen. Never hot enough to be too hot to the touch with bare hands, so the temper wasn't affected. I was concerned about the tip, since it's pretty thin. BTE it's about 0.022, so it's a fairly beefy blade. Thanks for looking & as always, comments are appreciated.
