ScarFoot
- Sep 16, 2021
So I went through my scrap bin a few weeks ago and decided to give a few old blanks another chance. They were all 1095 and W2 with an odd 1075 thrown in. I heat treated them all again and tried a few different things this time. A few of these blanks failed 2 previous hardening attempts miserably. The failed heat treat protocol for the 1095/W2 blanks was to soak at 1465F for 15 minutes and quench in ambient Parks 50. Out of the quench into a 300F snap temper, Then a 2x2 tempering cycle at 405F which was giving me 60-61 HRc on my test pieces.
The protocol I ran the other night was to soak at 1435F for 15 minutes then quench in oil or brine, both at ambient temp. The oil was about 2 gallons of Parks 50, the brine was 5 gallons of water with about 3.5 pounds of salt. I kept adding salt until it stopped dissolving easily. After quench they were snap tempered at 300F and then 2x2 tempering cycles at 405. After tempering, the brine quenched 1095 and W2 blanks are 64 HRC. I did check against a cal block and checked 3 locations per blank. The other water quenched 1095 blank tested out at 62HRC but is much thicker than the other two (0.125” vs 0.073”) so I wasn’t surprised it was a bit softer.
Anyway, I was expecting them all to be around 60 HRC. I can understand them being slightly higher but, 64 HRC after 2 tempering cycles seems a bit odd. All were surface ground prior to testing in all cases and in all cases they were all tempered together. I’m not sure if it was the brine quench or the lower soak temp or both that made the difference but something clearly worked this time that didn’t the last two times. I’ll just have to temper them down a bit.
The 1075 came out right where the knife engineering book said it would.
I don’t really know what to take away from this but at least I got a few data points to play with.
