I have a 5 gallon pale half filled with rain water(cold) and planned to add a gallon of hot water from the tap. I have 2 blades claycoated and almost dry. Should be dry by tonight.
Ideas?
Mike
The only point that I'd make is while brine is a faster quench and thus harsher, it actually tends to be LESS harsh as far as cracking a blade goes. This is counter intuitive, but it works that way because plain water forms a steam jacket around the blade which is uneven and causes uneven cooling of the blade, but a salt water / brine quench the salt content of the water disrupts the vapor jacket and allows more even contact of the water with the blade on both sides and tends to get less warping and "ping of death"
Well I did my water quench. Other than warping everything went ok. I used half room temp water and half hot water from the tap and had no cracking in either blade. I also scraped the spine clean figuring it might reduce the chance of cracking. I can see the hamon at 120grit so I'm hoping some interesting things show up throughout the polishing process. So far it looks like the best one I have created yet. The most detailed by far. I wish I had some ferric chloride though. I can't seem to find it here in Canada and no one will ship it because it can't be shipped by air (apparently). I will post pics when the polishing is complete.
Mike
