I look at things a little different. If there's a bunch of gunk I squirt a little WD-40 into it and then work the blade and then dry it off with a clean rag. I use Never Dull on the bolsters to shine the brass. Unlike Brasso, Never Dull will not wear down the brass.
I've got an older buck 112 with beautiful wooden handles. How should I clean and protect the handles?
Field dressing leaves a folder about as bad as it gets, not to mention I usually don't get to properly clean my knife until hours later. Soak in hot soapy water and clean the inside out with a toothpick. Spray out the insides with WD40, wipe off, then lightly oil, wipe again. It's then ready to cut some vension summer sausage. May not want to show the pic to anyone else eating the summer sausage.
well i have been reading this with interest
and now want to add my thoughts ..
cleaning :
if you use it on food that is so very important i can not begin to stress how important.
right after use is best and soap and water work great
cleaning later - well i would think alcohol would be best if it is not cleaned often!
for treating the wood scales on a food use knife i would use mineral oil!!
veg oil will turn rancid and wd40 .. well if you want to eat it it is ok with me..
i dont think a little will hurt you maybe..
for food use again mineral oil is my home use choice or a food grade lub like they use in food processing plants
for use on construction sites, yep any oil is great including 10w40..
Yep David your right on.TonyB is that the Ind.buck which you cleaned w/ your CS 110 w/ partial serrated blade which I believe you stated weighed 240lbs?DM
So, live wt. could have been 250lbs.? DM
