- Nov 13, 2008
Would a lanyard hole be possible on a buck 110 maybe from the custom shop jut below where the blade meets the back bolster possibly? Big advocate of lanyard use.
Ok, I've been biting my tongue reading this thread but after reading Ohen's post, I need to chime in.
There actually is a prototype of the very thing described in the posts above. What the engineers did was made a spring holder that extended out the back of the knife with a hole in it for a lanyard. I saw the proto and although I am not an expert on skull crushing, I can say with certainty that I would not like that thing coming down on my melon!
Unfortunately, the proto never became a project.![]()
There is a 110 complete with "skullcrusher" on slee-bay!
Don Seals put one together and has it there. I have nothing to do with it, just though others may want to know.
I didnt even remember that the rubber bucky had a lanyard hole.You all need to go Dave's "Rubber Bucky" thread and get added to the pass around list for this knife as Dave has drilled a lanyard hole in the rear bolster of that knife. Or perhaps Dave can post a photo of that knife whenever he gets it back.
well it is midnight and i looked and gee wizz the camera batteries had charged!
so was able to pull off the picts i had and take new ones..
of course it is signed and marked 'rubber bucky'
the real reason for this shot is ...
take note of the thickness of the brass on either
side of the rocker bar.. one side is much thicker!
on checking i have not seen this on others i have yet.
this hints at that they come from two different batches of stock!
any one else noticed any thing like this?
old and new side by side and Jacks sheath
you can see were the blade is short and clip is brought down,
to me it has a little bit of 'fighter' look
(i am still thinking this sheath is a keeper after the field testing)
close up of alpha rubber grips
how i got the blade looking
some of that old time "Glue" that buck used and how it hangs in there
some other thread there was much discusson on the thickness
of were it joined to the bolsters this shows how thick it is
and it is color gray green not dark like the wood
so it is the buffing that blends it in not its color
were it would not let go the wood or brass! dayum tough stuff!
